  • Posted by Jimr on November 18, 2005 at 10:16 pm
    Is there a way to Import Music from a CD
    and place in a Pal Seq Without Rendering
    I imported it into Itunes @48kz And then into my SeQ set at Pal anamorphic @48kz
    and im getting a Red line to Render
    Thanx JimR
    Tore Jonssen replied 20 years, 10 months ago 4 Members · 4 Replies
  • Scott Brown
    November 18, 2005 at 11:42 pm
    Hi Jim
    Your music must be in AIFF format at 48Khz for FCP…I suspect i tunes is bringing in your music as AAC or perhaps even MP3 format.
    Check your preferences option for import in i tunes.
    Hope this helps.
    Best wishes
    Scott
  • Jimr
    November 19, 2005 at 10:53 pm
    My File is an Aiff @48kz
    If I put it in a NTSC seq. if plays fine (no Render)
    If i put it in a PAL Seq. It needs to be rendered?
    all my other tracks brought in from PAL tapes play Fine.
    Is it a Problem because the SEQ. is at @25fps
    I never noticed this before.
    Thanx
    JimR
  • Neil Ryan
    November 21, 2005 at 4:22 am
    Maybe …
    Try opening the audio file in QuickTime and exporting it as an Aiff at 48k 16bit (the same as you say it is, now)
    Import that into the PAL project and see how it goes …
  • Tore Jonssen
    November 21, 2005 at 9:32 am
    This should not be a problem. I work in PAL and import 48 kHz 16 bit .aiff files all the time, without having to render..
