Activity › Forums › DVD Authoring › PAL-M DVD for Brazil
Posted by Patrick Edwards on October 28, 2011 at 3:34 amIt is my understanding that Brazil uses the PAL-M format:
1. Is there such thing as a PAL-M DVD
2. What format should I author a DVD for Brazil players?Gerry Mooney replied 14 years, 11 months ago 5 Members · 8 Replies -
Eric Pautsch
October 28, 2011 at 4:25 amDVD is NTSC and PAL only.
Actually PAL-M is a derivative of NTSC so deliver that. Remember NTSC plays on almost all player worldwide.
Michael Slowe
October 30, 2011 at 9:02 pmOh no it doesn’t, not here in London anyhow!
Michael Slowe
Gerry Mooney
October 31, 2011 at 2:25 pmI have a similar question: I’m in New York, and currently authoring a DVD that needs to play in Singapore. I’ve told the client that it will absolutely play on DVD players in Singapore but I’m still trying to confirm the best way to go about it. I did read the other day that NTSC content will play on most PAL players, and I see it repeated here, except for Michael’s post. Is there a definitive answer?
“I’m not half-insect, I’m half-human!”
Eric Pautsch
October 31, 2011 at 3:52 pmYes….almost all PAL players worldwide will play NTSC discs. There are a few exception models which I dont have in front of my right now. The only issue you might run into is if someone has an older TV
Gawd! You you imagine what would happen if people in Hong Kong and Singapore couldnt watch their pirated NTSC discs? 🙂 Not that all pirated stuff is NTSC but a large majority of it is.
I personally have at least 300K NTSC units Ive authored floating around Europe with no issues.
Make sure your regions are Open. Remember when the Predident presented a disc to the PM which didnt play? The region settings were wrong. 🙂
Gerry Mooney
October 31, 2011 at 5:49 pmHi Eric, thanks for your reply. I have one other question because the dvd I’m authoring is a music video. I read somewhere here on a CC blog that playing an NTSC disc on a PAL player, the timing can change, i.e., the music will keep its pitch, but the play speed may not be correct. Can you tell me anything about this possibility?
Eric Pautsch
October 31, 2011 at 6:43 pmNo….thats only if you were doing a standards conversion before authoring.
Here’s a good thread to read:
forums.creativecow.net/thread/55/860307#860308
Gerry Mooney
November 2, 2011 at 1:47 pmYep, that’s a great read and very helpful.
This NTSC/PAL thing is a bit of a distraction. I’ve been working on this animated music video for three-plus years and focusing mainly on DV vs. HD, and making sure the file I output is correct for Adobe Encore, and to have all this come up right at the end (I’m delivering it in Dec.) is not something I want to be spending time on!
