  • Posted by Scott Davis on July 16, 2009 at 10:28 pm
    Hey, All-
    I’m trying to dump to tape in PAL, something I’ve done countless times. Settings are correct, videos have been converted in Compressor as always, sequence is correct and matches the clips so no render involved. When I try to print to tape on a DSR-11 with switch in PAL, the print finds the edit point, cues up, starts the edit, and the video and audio are all garbled up.
    1. Anyone else see this?
    2. How did you fix it?
    3. Any good deals on a new monitor, because I’m about to put my foot through mine, I’m that frustrated… I have not done ANYTHING differently than in the past…
    HELP!
    Scott
    OSX 10.5.5
    Quad 2.5Ghz
    8.5 GB RAM
    Final Cut Studio 6.0.4
    HPX 2000
    Jaap Verdenius replied 17 years, 2 months ago 2 Members · 1 Reply
  • Jaap Verdenius
    July 21, 2009 at 11:51 pm
    I haven’t seen it, but
    – were you able to play your sequence correctly from FCP to a PAL monitor? Just to exclude that the sequence is the problem.
    – did you set the DSR11’s audio settings from 32kHz back to 48kHz? I remember that it tended to switch back to 32kKz which always caused some kind of problems.
