Activity Forums Panasonic Cameras PAL footage into FCP
  • PAL footage into FCP
    Posted by Koma83 on May 18, 2006 at 5:09 am
    I am an Australian member wanting to import 1080p 25fps footage from a Panasonic P2 card into FCP. Is this possible as yet?
    I am using FCP 5.0.4, QT 7.0.3 and OSX 10.3.9. I have watched Shane’s tutorial which says that I need 10.4.3 to import, but am not sure if this is the only thing I’m doing wrong. I have been able to import one of my clips but not the others – coming up with error msg ‘one or more p2 clips failed to import; probable incomplete or corrupt clips.’
    Does anyone know what could be the problem here?
    Koma83
    Yves Chauvel replied 20 years, 3 months ago 6 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    May 18, 2006 at 4:09 pm
    AFAIK- PAL 25p is not yet supported under FCP. You might check with DVfilm.com I believe they may have some sort of workaround available.
    Noah
  • Gunleik Groven
    May 18, 2006 at 7:25 pm
    1080 shouldn’t be a problem, just drop it in an i50 timeline and off you go. You may want to set the field dominance to “none”.
    This is how Varicam footage is edited:
    Upconvert in 1200 deck to 1080 and edit as 25 pfs (i.e. in a i50 timeline)
    Gunleik
  • Yves Chauvel
    May 20, 2006 at 9:55 am
    Both 1080/50i and 1080/25P are currently supported with FCP 5.0.4. Any 720P flavor is not supported yet for Pal users.
    We have made tests on a G5, a I-Book and a Powerbook( Quicktime 7.0.4, OS 10.4.6) connecting either the camera through firewire or the P2 store through USB. We ‘ve used internal drives and an external 1 To LaCie drive
    1080/50i and 1080/25P can be mixed on the same sequence without any rendering.
    We have made a 2 weeks shooting and charts trial and have been surprised by the fact the unit we have tested underexposed in most shooting conditions over 1 F stop.
    For those among you who can read french, go to:
    https://hdvplus.net/AG-HVX200-Panasonic.pdf
    Sorry, if it is not available in english yet.
    Yves
  • Koma83
    May 23, 2006 at 5:03 am
    Thanks for the tips! Will see how I go….
  • Dan Montgomery
    May 25, 2006 at 10:15 pm
    Or, you could try out the newest HD Log demo we posted yesterday that appears to solve the PAL 720 issues 😉
    You should be able to view 720/25 or 50, and create QT files of selected P2 clips.
    Video logging is just the beginning…
  • Gary Adcock
    May 26, 2006 at 1:06 am
    [Dan Montgomery] “You should be able to view 720/25 or 50, and create QT files of selected P2 clips.”
    Bless you Dan@!!!!!
    it works Great!!
    gary
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
    gary@studio37.com
  • Yves Chauvel
    May 31, 2006 at 8:49 pm
    Thanks Dan for the HD Log info and 720/25 or 50 editing!
    Have not tried that yet.
