Activity › Forums › Apple Final Cut Pro Legacy › PAL dvd looking good, NTSC dvd looking horrible
  • PAL dvd looking good, NTSC dvd looking horrible
    Posted by Andrew Thomson on September 27, 2005 at 12:21 am
    I have PAL DV video edited in FCP HD for use on both PAL and NTSC DVD’s. The export Mov’s from FCP HD go through Compressor where they are compressed into both PAL and NTSC .mpv’s. The two encodes are made from the same Mov file. The DVD projects are authored in Scenarist. The PAL encodes once made into a DVD are fine, but the NTSC ones jerk along quite badly on the pans and zooms, and have serious interlacing going on.
    Should I be looking to fix settings in FCP HD or Compressor? Playing around with Deinterlacing on particular shots in the FCP edit, and/or swapping other sequence settings do not seem to make much difference to the eventual NTSC DVD video.
    In FCP HD the settings are pretty much default for PAL, CCIR601 / DV PAL 5:4, with Safe RT. The Movs are exported as ‘Current Settings’.
    The encoder settings are as follows:
    Description: 5Mbps,2-Pass VBR,4:3, filters
    File Extension: m2v
    Video Encoder
    Format: M2V
    Width: 720
    Height: 480
    Pixel aspect ratio: 1.125
    Crop: None
    Frame rate: 29.97
    Aspect ratio: 4:3
    Field dominance: Bottom first
    Average data rate: 5 (Mbps)
    2 Pass VBR enabled
    Maximum data rate: 8 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 15, Structure: IBBP
    Noise Removal
    Apply To: All Channels
    Iterations: 1
    Algorithm: Replace
    Sharpen Edge
    Amount: 0.000000
    File Extension: m2v
    Video Encoder
    Format: M2V
    Width: 720
    Height: 576
    Pixel aspect ratio: 0.938
    Crop: None
    Frame rate: 25
    Aspect ratio: 4:3
    2 Pass VBR enabled
    High quality
    Closed GOP Size: 12, Structure: IBBP
    I know its going to have some kind of quality change going from PAL to NTSC, but there must be a way to make a better image than this! 🙂 Any suggestions?
    Thankyou in advance.
    hybridyak
    We are always in all ways nowhere. Now. Here.
    Jerry Hofmann replied 21 years ago 2 Members · 1 Reply
  • Jerry Hofmann
    September 27, 2005 at 2:32 pm
    You need the Nattress plugin with FCP HD… it will do a dandy standards conversion, and then compressed the NTSC version the way you are… works great! https://www.nattress.com
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
