Activity Forums Avid Media Composer Pal Dv or Pal 601 for import?
  • Pal Dv or Pal 601 for import?
    Posted by Herbid Mulyo on April 27, 2009 at 8:16 am
    From Avid Help Menu:
    If the field order of the graphic is not correct, select the field order of the graphic during Import and the application reverses the fields appropriately.
    For interlaced media, your Avid editing application uses the following order:
    Pal 601: upper field first
    Pal Dv: lower field first
    Q: How we define that material to import is Pal 601 or Pal Dv?
    Herbid Mulyo replied 17 years, 4 months ago 1 Member · 1 Reply
