Activity Forums Apple Final Cut Pro Legacy PAL dub Master
  • Posted by Brian Pitt on January 19, 2006 at 4:27 pm
    I know this probably isn’t the forum to post this, but people in here seem to know what they are talking about moreso than in the other forums.
    I have an NTSC master of a DVD that our company will be mass-producing. I need to make a PAL dub master from the NTSC DVD. Is this possible, and if so, how do I do this?
    Brian Pitt replied 20 years, 8 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    January 20, 2006 at 2:08 pm
    It would be much better if you did not use the DVD as the “master footage” for the NTSC-to-PAL conversion.
    The DVD is already severely compressed and will not give you the best results.
    If you DO need to use the DVD as a master, you can convert the audio/video files back to an editable form by using DVD “ripping” software.
    Popular Mac choices:
    https://www.dvdxdv.com/
    https://www.miraizon.com/products/products.html
    https://www.alfanet.it/squared5/mpegstreamclip.html
    But, again, if you can go back to the original edited footage that was used to create the DVD, that would be a better place to start.
    Regardless, you will need to use a “standards convertor” to make the change in format.
    In FCP, one of the most popular choices comes from Graeme Nattress.
    https://www.nattress.com/standardsConversion.htm
    Systems conversion always results in somewhat artifacted, lowered-quality images.
    Start with the highest quality image you can.
  • Brian Pitt
    January 20, 2006 at 4:31 pm
    Thanks for the reply. I think that I’ll create a master on DVCPRO NTSC and use a standards converter box to make a PAL master. From there, I will just import the Pal footage and author that way.
