Activity Forums VEGAS Pro PAL Default
  • PAL Default
    Posted by Brian Jones on January 14, 2011 at 1:58 pm
    I am running Sony DVD Architect Pro 5.2 and Sony Vegas 10.0b. I am in a PAL country and do all my work in HDV 1080-50i (1440×1080, 25.000 fps). When I run DVD Architect Pro and select “New”, I’m presented with the usual “New Project” dialog box. Unfortunately, it always defaults to Format: Mpeg-2 720×480-60i 4.3(NTSC). If I change it to my PAL requirements it will work fine but will default to the former NTSC settings next time I select “New”.
    There is no check box to change the default, so how can I set DVD Architect Pro 5.2 to default to PAL?
    I’m falling on the wisdom and experience of more knowledgeable people than I am.
    Mike Kujbida replied 15 years, 8 months ago 2 Members · 1 Reply
  • Mike Kujbida
    January 14, 2011 at 2:16 pm
    “There is no check box to change the default, so how can I set DVD Architect Pro 5.2 to default to PAL?”
    I get a check box on my DVDA screen (I’m in NTSC land) and can confirm that it works when checked.
