Activity › Forums › Apple Final Cut Pro Legacy › PAL conversion
  • Posted by Scott Van beever on July 23, 2007 at 7:17 pm
    My clients are mostly in Europe. When I create an NTSC project (all footage is NTSC) and am ready to export and create a DVD, what is the best way to get them the best quality quicktime? Should I do a conversion in Final Cut and make a PAL quicktime, or simply make the iDVD setting to PAL disk?
    Uli Plank replied 19 years, 2 months ago 3 Members · 2 Replies
  • Russell Lasson
    July 23, 2007 at 7:41 pm
    Depending on how your client will use it, you might not need to convert the file to PAL. Many modern DVD Players in Europe play back both PAL and NTSC. Make sure they know what they want.
    For PAL conversions, I use Nattress Standards Converter.
    -Russ
  • Uli Plank
    July 24, 2007 at 5:32 am
    ALL DVD players in Europe can play NTSC, but not all TVs will show that signal. Check with your client.
    If you want to convert, I second the recommendation for Nattress’ G Converter.
    Regards,
    Uli
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
