Activity › Forums › Apple Final Cut Pro Legacy › Pal Conversion
  • Posted by Carlo Ferraro on May 20, 2009 at 3:02 pm
    I work on HDV NTSC but I keep the masters in APPLE PRORES HQ 1920X1080.
    I need to convert some masters stored in
    APPLE PRORES HQ 1920X1080 60i.mov TO PAL.mov.
    The only chance I see in FCP is the conversion to APPLE PRORES HQ PAL, but the resulting file isless than one third smaller than the original NTSC. The ratio is 1 to 3.5.
    Any idea of why?
    Any other suggested way of conversion?
    Carlo Ferraro
    Mike Raff replied 17 years, 4 months ago 2 Members · 2 Replies
  • Carlo Ferraro
    May 20, 2009 at 3:36 pm
    Got it, it converts to standard definition…
    Still searching to convert APPLE PRO RES 1920X1080 from NTSC to PAL..
    Help needed
  • Mike Raff
    May 20, 2009 at 4:33 pm
    Hi, Carlo
    I’ve never done this myself, but I’ve looked into it. The two primary options are hardware or software. The hardware is expensive to purchase, but many post-houses who have invested in it offer standards conversion as a service. If you have the time and money, you might find someone who can do this for you.
    As for software, if you are willing to spend some money, Graham Nattress makes a standards conversion plug-in which many folks recommend.
    https://www.nattress.com/Products/standardsconversion/standardsconversion.htm
    If you are comfortable with Compressor, I think you can accomplish this by selecting Settings>Apple>Other Workflows>Advanced Format Conversions>Apple Codecs>Apple ProRes 422 for Interlaced Material (High Quality). Apply that to your clip, then in the Inspector window, select the Frame Controls icon. Turn Frame Controls ON and go down to the Retiming Control.
    See the Compressor User Manual, Chapter 20, page 264 “Using Retiming Control” and then ask someone more knowledgeable than me!
    Good luck.
    Mike Raff
    Richmond, VA
