Activity Forums Blackmagic Design PAL colour bars 75% or 100%
  • PAL colour bars 75% or 100%
    Posted by George Evatt on August 29, 2006 at 12:49 pm
    I have to output a short 16:9 program to PAL Digibetacam using Premiere Pro 2 and a decklink SDi card. Does anyone know what is the correct broadcast level for the colour bars 75% or 100%? The default Premiere Pro bars are set at 75%, but the test bars that come with Decklink are 100% (I can see this in the vectorscope).
    So the question is what is the correct level to have colour bars for broadcast TV in a Pal country like Australia 75% or 100%?
    George
    George Evatt replied 20 years ago 3 Members · 3 Replies
  • Rory Hinds
    August 29, 2006 at 2:52 pm
    100% are the PAL standard and 75% are for NTSC (normally)
    Rory Hinds
    http://www.whatismine.com
  • Rafael Amador
    August 30, 2006 at 4:00 am
    Hi George,
    The official UER bars (PAL) are 75% level and 100% saturation, except the white one that is 100% (luminance=1, saturation=0 ).
    If the bars would be 100%, they would be simply “ilegal”.
    The SMTP bars (NTSC) are the same than the UER, but the white (gray) is 75% luma.
    When you use the bars you have to see that they reach the small boxes in the vectorscope, without over
    passing (sorry by my English).
    Salud.
    Rafael
  • George Evatt
    August 30, 2006 at 9:10 pm
    Thanks Rory and Rafalaos for the tips.
    Regards
    George
