Activity › Forums › Compression Techniques › PAL anamorphic movie to NTSC .m2v – resize settings?
  • PAL anamorphic movie to NTSC .m2v – resize settings?
    Posted by Dima Venkov on February 20, 2009 at 12:25 am
    I’m trying to convert my movie shot in PAL anamorphic mode into an NTSC .m2v file for DVD Studio Pro. What resize settings should I be using in Episode Pro to keep the widescreen proportions? 720X406?
    Dima Venkov replied 17 years, 7 months ago 2 Members · 6 Replies
  • Dima Venkov
    February 20, 2009 at 9:48 am
    update: tried 720×406 – wrong aspect ratio
  • Dima Venkov
    February 20, 2009 at 10:13 am
    I see that After Effects has an NTSC D1 Widescreen Square Pixel preset 865×486 – is this the the resize settings I should apply in Episode?
  • Daniel Low
    February 20, 2009 at 1:12 pm
    Episode has a bunch of presets for Standards conversion, have you tried these?
    720×480
    Maintain proportions with None (Distort)
    Source Display Aspect ratio – Pass through or force it by using ‘assume’
    Fonts are like cologne:
    A bad choice speaks louder than a good one.
  • Dima Venkov
    February 20, 2009 at 3:47 pm
    tried that – but the m2v comes out 4×3 squeezed horizontally. The 846×486 also comes out 4×3 and is not recognized by DVD Studio Pro. What the…?
    If Toast can make an NTSC DVD from a PAL movie with just one click, Episode should definitely be able to do that too, ain’t it?
  • Daniel Low
    February 20, 2009 at 4:06 pm
    What are you using to view the m2v?
  • Dima Venkov
    February 20, 2009 at 4:13 pm
    I imported it into DVD Studio Pro, viewed it in Mpeg Streamclip, and as preview in finder (space bar) – looks the same.
