Activity Forums Adobe After Effects PAL 30fps to PAL 25fps How???
  • PAL 30fps to PAL 25fps How???
    Posted by Asif Limbada on February 25, 2009 at 10:55 am
    I have recently purchased a Canon 5D Mark 2, as I reside in Indian Subcontinent, TV Channels here use DVPAL at 25 fps. Now the issue is I am working on a project which requires 25 fps in PAL, Canon 5D Mark 2 has a PAL video system, but does record in 25 fps but in 30 fps.
    This is a big issue…there are some workarounds such as the FPS Convertor and stuff, but its confuses me more.
    Then I checked Adobe After effects help file, used Pixel Motion for Frame Blending, but I rendered it I see interlacing issues(lines getting distorted…i think, I’m a newbie). And it takes ages to render the file, I will be working on 2 hours of footage and I don’t know how to tackle this issue easily…
    I really need help guys…
    thanks
    J. Mechanicus replied 17 years, 5 months ago 5 Members · 6 Replies
  • Chris Wright
    February 25, 2009 at 9:27 pm
    There’s Natress, AE’s timewarp, and twixtor. I would search by keyword about these and decide which route to go.
  • Simon Twine
    February 26, 2009 at 5:50 am
    Dave, i think the 5D Mark 2 is hard-coded to 30fps regardless of where you buy it. I dont even think it is 29.97, although i could be wrong.
    I dont think there are any settings to change this (much to the chagrin of most 5D Mk II buyers/potential buyers).
    I guess that is the compromise you make when you use a DSLR to record video!
    Asif – take a look at Vincent Laforet’s blog – he is currently shooting a doc on the 5D Mk II and i think he had some details on his workflow on his blog.
    Good luck!
    Si
  • Simon Twine
    February 27, 2009 at 12:50 am
    The false economy depends i guess – probably for him, yes. But if you take a look at Vincent Laforet’s work with the 5D Mk II you’ll see the potential that camera has – you just need to know what you’re getting yourself into (and have a bucketload of fast glass available to you).
    For filming broadcast PAL – big mistake.
  • Asif Limbada
    April 3, 2009 at 9:23 pm
    Just used Compressor in FCP to convert .mov file with h.624 pal 30 fps to ProRes Pal 25, works perfectly, I hope i wouldnt have to do that all the time, there is a rumour that in April Canon will release new firmware to address this issue, because probably the europeans and asians are not buying it that much.
  • Chris Tangey
    April 10, 2009 at 11:45 pm
    You say Pro res PAL 25, what actual setting are you talking about?
    Everything I see listed says it is based on the source material frame rate (presumably 30fps) Thanks.
  • J. Mechanicus
    April 27, 2009 at 11:15 pm
    Asif,
    Could you be so kind to drop some settings here.
    I’m in trying hard to get 30fps to 25. Looks like I succeed but I’m not shure yet.
    Kind regards.
    Ps. screenshots will do.
