Activity › Forums › Apple Final Cut Pro Legacy › PAKISTAN Calling!!!!
Posted by Moth Man on May 26, 2006 at 10:21 pmHi,
I am trying to see how to convert a video footage that I shot on DVX100 in PAL format at 25fps. The conversion I am looking for is the film feel (like a 24fps) but I need the output on PAL so that it can be broadcasted on PAL TV station.
I have used 8 bit uncompressed injest in FCP 5 and now am looking at various ways to output a ‘close to film feel’. Is there any other way to make the film/video move a bit slower (artistic affect) while it also syncs with the sound?
I need your help!
Nick Meyers replied 20 years, 3 months ago 6 Members · 8 Replies -
Jeremy Garchow
May 26, 2006 at 11:13 pm -
Bob Roberts
May 27, 2006 at 3:50 am1) Use 3-way color correction to bring down the black levels to a solid black and the brights less than white so you have some detail in your highlights.
2) Use any type of “field blend” filter. (Nattress, Magic Bullet, Too Much Too Soon [TMTS], Joe’s Filters)
…that should go a long way.
Dopocc
May 27, 2006 at 3:59 amWhat about Red Giant’s – Magic Bullet Editor’s ? Although I believe that it processes video only in terms of “looks” and doesn’t change “motion”
https://www.redgiantsoftware.com/mbforeditors.html
I am not shure if their Magic Bullet Suite for After Effetcs that is capable of 24p could work for you..
https://www.redgiantsoftware.com/magbulsuit.html
Good Luck : )
Bill Belegris
Cinematographer
Renegade Arts Inc.
HD Cinematography, Audio Production
and Digital Content Creation Studio Services
Thissio, Athens, Greece -
David Slater
May 29, 2006 at 10:55 pmVery silly question
why do you want to convert from 25 to 24 and back to 25
there would be little difference
and a degradation as it would be a couple of generation’s of renders
and a major waste of timeyou have the “film look” already with shooting in PAL
DAVE at Movies Rock in Toronto
Moth Man
May 30, 2006 at 4:44 amOH well!!!! Thank you for the encouragement!!!! Anyways, what actually I am after is this…..”I want to run the video a little slow”……Like a strobe effect, but, umm…how do I put it….I want the Video to be 25 fps as it is PAL but I want it to run a bit slower than Video to give it a slightly unsettled effect?
Could you SIR, help?
I need your help!
Nick Meyers
May 30, 2006 at 12:49 pmDave, 25fps VIDEO does not look like film!
it still has 50 interlaced fields every second,
and that is one of e the main factors it it looking like video.
as opposed to the 24 or 25 Progressive frames of filmMoth Man is instinctively on the right track thinking about “Slowing down”
but what we’re really talking about is reducing the number of images seen every second.Moth Man,
a simple de-interlace filter will go along way to getting you where you want.
that’ll give you 25 discrete images every second.there’s a few more tricks to getting a film look,
and you can do a lot with a bunch of individual plugins,
or you can get the Nattress package for what is ridiculously cheap.weird thing:
i’m pretty sure DID write a post outlining a whole bunch of freebie plugins that would help you.
did you get that?
it seems to have been removed?cheers,
nick -
Moth Man
May 30, 2006 at 8:10 pmYes please, I’d be greatly insterested to know the name of the plug-in and the company. I never got any free plug-ins? Would they help me ‘deinterlace’ as you have suggested? I mean would that filter slow-down/ I mean will it give me a ‘slow-down’ effect.
Please do reply.
Thanks a bunch.
I need your help!
Nick Meyers
May 30, 2006 at 10:32 pmi think i had some cookie malfunction last time, that;s why it didn’t go thru.
i never sent any plugins,
i sent a list of some plugins for FCPFCP has a de-interlace filter you can use
no it wont slow your shot down.
it will do what i said,
reduce the number if individual images you see per second,
pulling it more into line with a film frame rateIf you Do simply want to slow the shot,
try Modify Menu > Speed
& look up “speed” in the manual.partial list of free plug ins helpful in creating a “Film Look”
Too Much Too Soon:
https://www.mattias.nu/plugins/
Fast De-INterlace,
Blend Fields,
DiffusionHaiku:
https://www.haiku.com.au/2005/08/final-cut-pro-plug-ins.html
Vignette,
FacelightRanier’s Wiggle:
https://www.digiconform.com/
(not direct link, flash site, you’ll have to find it)
this can simulate jumping in gate.here’s a list of all sorts of free plugins for FCP:
https://www.digitalzoo.com.au/lunchtime/lunch_docs/related_02_free.htmsame site has list of all (?) filter foundries for FCP
as i said the Graeme Nattress plugins are very cheap and good.
cheers,
nick
