… There is no good way to do this that isn’t insanely kludgy.
The quickest way for a large project would probably be to create copies of your proxy footage, sync/replace your production audio within the file using DualEyes, and then in Premiere, doing a match frame (f key) and overwrite editing the footage back into the edit. The last part with Premiere is because you’ll probably be creating multiple new audio layers (I assume your production audio is 4+ channels) and Premiere doesn’t do this and place in the new multichannel audio automatically.
Beyond that, I don’t think any “clever solutions” will beat manually syncing each cut either with the clapper or, if there is timecode, using the synchronize command. This will create a new merged clip then you rebuild the edit with your original locked edit as a reference.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
