Activity Forums Adobe After Effects Painting w/ an Image Reference?
  • Painting w/ an Image Reference?
    Posted by Max Jackson on September 17, 2012 at 11:05 pm
    As I understand it, Adobe use to have something called vector paint which was removed in CS5.
    I’ve read the adobe docs on paint/stamp/erase and how you have to control these tool in the layer itself.
    Well, that’s all fine and dandy but how the heck do I trace something? Is bezier masking the only way to do this? Not being able to draw a feathered mask on top of an image using a brush seems really counterproductive.
    Is there any technique around this latest development? When I’m in “Layer Mode” I can see what I’m trying to draw on top of. really frustrating.
    Thanks for any help.
    Max Jackson replied 14 years ago 2 Members · 9 Replies
  • 9 Replies
  • John Cuevas
    September 18, 2012 at 12:02 am
    I don’t understand why you can’t see the layer? I just dropped a jpeg into a comp, opened up it’s layer window, selected the paintbrush and started tracing around the picture(badly, but I can still see everything).
    When you are in the layer window, do you have view set to “Paint” and the Render box checked?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Max Jackson
    September 18, 2012 at 12:26 am
    Well I can paint on the image, yes. But the paint is flattened to the image. I want to see the image as a reference guide and paint on top of it separately so what I’m painting is the mask?
    Know what I mean? At this point I can’t figure out how to do this in After Effects, only in Photoshop.
  • John Cuevas
    September 18, 2012 at 1:09 am
    I think I’m following. Couldn’t you use paint on the image and then when you are finished, just click the paint effect and change the mode to “Paint on Transparent” And if you want you could put another copy of the image below that layer?
    I’m not sure what you mean by the mask as I think that means something different in photoshop than it does in AE. Perhaps I’m not fully understanding what you are trying to accomplish.
    Thinkck.com
  • Max Jackson
    September 18, 2012 at 1:22 am
    Right, mask is probably bad terminology. Also, my bad, the paint isn’t flattened to the image in layer mode. it’s a wire on top that you can move around. That’s way comforting.
    One thing though, I’m still in layer mode. How do I get this paint on the image in layer mode to it’s own solid or layer to use as a matte or blend mode layer effect?
    Thanks John.
  • John Cuevas
    September 18, 2012 at 11:38 am
    Go back to comp mode, select the layer with the paint effect and press “E” to reveal the effects and twirl open “Paint” You have some options here, you can individually change each paint layer to be a different transfer mode. Or you can change the paint toggle “Paint on Transparent” to on. Now you can use that as an alpha matte for the layer below if you want. Or you could animate the brush strokes to reveal a layer by animating the start and end parameters under the stroke options.
    Each brush stroke also has parameters that can be further adjusted, color,
    Thinkck.com
  • Max Jackson
    September 18, 2012 at 9:20 pm
    When I click the Paint on Transparent ‘on’ the whole frame goes black. I got it to show transparent through the image, but then now all it does is show a black canvas.
    Know what I did wrong at all?
    Thanks for your help, it’s really encouraging. I’ll have to see if I can’t find some more tutorials on using the paint tool.
  • John Cuevas
    September 18, 2012 at 9:49 pm
    Are you painting with black paint over a black background? If that’s the case change push the checkboard icon below the comp window.
    Only Tutorial I know of using the paint filter/effect.
    Thinkck.com
  • Max Jackson
    September 18, 2012 at 11:10 pm
    I’m painting black on a JPG. I thought I hit the same on/off switch and it masked out what I painted, but i hit it again and from here on out it just turns the whole comp black. Heh, not sure what I did.
    Thanks John. 🙂
  • Max Jackson
    September 18, 2012 at 11:20 pm
    Actually you’re right. I get what you were saying now with the black on black. Silly me, that’s exactly what the problem was.
    Thanks John!
