Activity Forums Maxon Cinema 4D Painting Fur Placement
  • Painting Fur Placement
    Posted by Seth Olson on October 4, 2012 at 9:25 pm
    I am trying to use fur to create grass, but I’d like to be able to control the visibility and placement via alpha mat. Is there a way to control fur using textures?
    Seth
    Seth Olson replied 13 years, 11 months ago 2 Members · 2 Replies
  • Brian Jones
    October 5, 2012 at 12:41 am
    try using your alpha in the Hair Material’s Thickness/Length/Scale or Density parameters they all should give you control which depends on what you want for the end result.
  • Seth Olson
    October 5, 2012 at 7:02 pm
    oh! I will give that a try. I thought that was for the alpha of the individual blades/hairs. Thanks!
