Activity Forums Adobe Photoshop Painted high contrast effect
  • Painted high contrast effect
    Posted by Pluffsy on May 18, 2006 at 7:09 am
    Sorry if this has been up before. But I would very much like to learn how to create that painted, high contrast, saturated colors, surreal effect that some photos have. And I suppose the effect is too a big part made in the post production in photoshop.
    A lot of hollywood movies have this effect too, Lord of the Rings for example.
    This is an example of what I mean:
    https://www.lovisaringborg.se/gallery1/5.htm
    Thanks for your time
    Regards Emil
    Jeff Cochran replied 20 years, 4 months ago 2 Members · 1 Reply
  • Jeff Cochran
    May 24, 2006 at 5:36 pm
    Try this
    Duplicate the image on a new layer, use curves and really brighten up your Highlights. add a little bit of gaussain blur to soften, then give the layer a transfer mode of screen. You may have to adjust the opacity a bit.
    Now add an adjustment layer using hue and saturation. Bump the saturation a bit. You can even try adjusting the sat. for certian color. (The blues and greens for instance)
    Play around with that, I think this can give you what your looking for.
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
