Activity › Forums › Apple Motion › Paint stroke / ink bleed effect speed
  • Paint stroke / ink bleed effect speed
    Posted by John Baldino on April 26, 2010 at 5:36 pm
    Hi guys,
    Does anyone know if you can change the speed parameter for the animated brush stroke effect that Stephen Smith talks about in his “painting with motion” tutorial? I want to use the effect as a lower 3rd, but I want to speed up the rate at which it draws itself. Maybe I’m really slow, but for the life of me I can’t find the parameter in the inspector.
    When I scrub through the timeline and look at the effect parameters on the left, none of the values seem to change. So what I’m wondering is, is the speed a fixed value? It seems like this should be so easy to fix, but I just can’t find the parameter.
    Any thoughts welcomed!
    John Baldino replied 16 years, 5 months ago 3 Members · 3 Replies
  • Mark Spencer
    April 26, 2010 at 5:45 pm
    It’s the Last Point Offset that’s being keyframed – bottom of the Style pane of the Shape Inspector. Choose Reveal in Keyframe Editor from the Animation menu. But easiest way to adjust it is to go the the Timeline, click the show/hide keyframes button at the bottom left if they aren’t showing, and drag the right keyframe to adjust the timing.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Stephen Smith
    April 26, 2010 at 5:47 pm
    Select the paint stroke. Go to the Keyframe Editor or select the show/hide keyframe button so the keyframes are showing in the timeline. Move the keyframe to adjust the speed and best of luck.
    Utah Video Productions
    Check out my Motion Tutorials
  • John Baldino
    April 26, 2010 at 6:34 pm
    Awesome. That’s it. That was so easy I should have been able to figure it out…but alas. The learning curve, as it were.
    Thanks for the quick & helpful response guys. Much appreciated.
