Activity › Forums › Adobe After Effects › paint out blemish on face
  • paint out blemish on face
    Posted by Deleted User on February 5, 2010 at 2:32 am
    I’m trying to determine the best approach to cloning out the large blemish on the guy’s face in this image here:
    I’m good with the stamp tool in Photoshop, but a moving image is altogether different…
    anyone know of a good tutorial which could set me in the right direction here?
    thanks for your help COWers!
    https://www.tatucreative.com
    twitter: @charleslittle2
    David Johnson replied 16 years, 7 months ago 5 Members · 6 Replies
  • Todd Kopriva
    February 5, 2010 at 5:53 am
    I’d try something like the Change To Color effect or maybe the Colorama effect to push the purple to the color of the surrounding skin. Animate a rough mask to follow the blemish (essentially, crude rotoscoping). Put this mask on an adjustment layer. Apply the color-change effect to the adjustment layer.
    Because you’re using color matching, you don’t even need to have a very precise mask.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • David Johnson
    February 5, 2010 at 12:29 pm
    I’m not in AE now so I can’t check to be sure it isn’t a third-party plugin, but using the same method Todd described, I’ve gotten much better results with a Tri-Tone plugin than Change Color or Change To Color. Colorama can do the same, but it requires more effort.
    The reason is, although they appear to be, skin pixels aren’t all one color so, without applying color variations, you’ll likely end up with a noticeable one-color patch over the corrected area.
    Whichever plugin you go with, it can also sometimes help to add a tiny bit of grain over the corrected area, although that depends on the footage and isn’t always necessary.
    Sometimes, I’ve also found it helpful to use a masked duplicate of the footage instead of or in addition to an adjustment layer, but again, that depends on the footage and isn’t always necessary.
    By the way, if you do it via painting, you’re creating extra work for yourself because you’ll probably have to motion track the paint to the footage.
  • Michael Szalapski
    February 5, 2010 at 2:17 pm
    Perhaps, once the client receives your bill, they will realize it is much easier to fix things like this during production with makeup.
    I agree with David and Todd’s suggestions. They should still work, even if he turns his neck and you get a wrinkle there.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Dave Johnson
    February 5, 2010 at 2:33 pm
    lol!
    Michael makes a great point … related to his point, don’t fall for it when clients or anyone else tries to convince you that this kind of post work is just part of regular “editing” that shouldn’t affect costs or turnaround time.
    It’s true an ever-increasing number and variety of things can be fixed in post nowadays, but very many people tend to conveniently forget (or refuse to understand/accept in the first place) that “fixing it in post” generally costs 3-5 times as much as fixing it during production … almost regardless of what the “it” is.
    By the way, I failed to mention in my first reply … don’t forget to feather your mask(s). Also, using blending modes and/or opacity can help resolve issues like wrinkles, textures, etc.
  • Deleted User
    February 6, 2010 at 2:12 am
    Thank you all so much for your input and suggestions. Yes I was able to quite effectively remove the blemish from the subjects face with an animated garbage matte that followed the birthmark.
    I then replaced the masked out area with another area of the subjects face that was blown up to approx 150%. I just performed a little color correction and the area moved together quite naturally.
    It’s not a broadcast quality piece of retouching by any means, but for this particular presentation reel, it did get the job done.
    If you’re interested I will post the results. I would be interested in your feedback on that as well.
    I love the COW.
    moo!
    Charles Little II
  • David Johnson
    February 6, 2010 at 8:37 pm
    Glad you found a solution. I for one would like to see the results … always helpful to see results of different methods.
