Activity Forums Maxon Cinema 4D paint joints mesh
  • paint joints mesh
    Posted by Mauricio Barrientos on April 5, 2025 at 9:38 pm
    Hello again, I’m using Cinema 4D version R25, and I’m painting the weight of the sjoints, to be affected with different strength, but the whole scene comes out very dark, and I would like to see what I’m painting on the arm, I ask, is there a way to clarify the mesh so I know where I’m painting and not lose me please? I’ll leave a photo…thank you and blessings
    Brie Clayton replied 1 year, 4 months ago 3 Members · 6 Replies
  • Kouraib Abdmalek
    April 6, 2025 at 10:54 am
    Hi Mauricio,
    Although the model is dark, it shows lines (albeit slightly faded) that show the details of the mesh. However, this is not how it is supposed to look when coloring the weight. I don’t know if it is like this for you in all models or only with this one. If this only happened to you after moving to the new version, there may be a feature activated somewhere that makes the display like this.
  • Mauricio Barrientos
    April 6, 2025 at 11:27 pm
    Honestly, it happens to me on all of them… in fact, I’m on the third one and it shows dark, could I change the color of the mesh better?
    What I’ve done, but I don’t think it’s optimal, is to change the color of the mesh. This solved the problem quite a bit, but I imagine there must be another way. Thanks a million, always.
  • Kouraib Abdmalek
    April 7, 2025 at 8:03 am
    You’re welcome, Mauricio! So your mesh color was dark, that’s why I said it wasn’t supposed to look like that because other colors are more common and easier to work with, but honestly I don’t know if there’s another way to radically overcome this.
    April 7, 2025 at 8:15 pm
    ok … thansk a lo t….
    i change the color of mesh lines and work for now thanks bless
  • Kouraib Abdmalek
    April 8, 2025 at 8:31 am
    You are welcome, Mauricio!
  • Brie Clayton
    April 8, 2025 at 1:36 pm
    Thank you for solving this, Kouraib!
