Activity › Forums › Maxon Cinema 4D › Paint for field (Football, soccer, etc)… how?
  • Paint for field (Football, soccer, etc)… how?
    Posted by Joseph M. morgan on July 17, 2007 at 2:02 am
    OK… so I’ve modelled a huge stadium… 3 tiers, lights for interior and exterior, ground, grass… etc… and I can’t figure out how to easily go about creating paint on the field.
    I started with a soccer field (thinking it would be easy). Well, guess what. It ain’t so easy. At the end of the day, I suppose I could start with a cube with a height of .1 and start cutting it up, but I can create the paint with much more precision with simple spline primitives.
    So, I’ve outlined the “paint” with exact measurements ( that is, to scale in feet ). Is there a way to convert these outlines to flat (or very thin) solids?
    That is, create a rectangle spline primitive 100 x 100. Then create another inside of it, say 99 x 99. How do I turn everything from the outer line to the inner line to a single plane or solid, such that the middle doesn’t fill?
    Joe
    Alejandro Torres replied 19 years, 2 months ago 2 Members · 4 Replies
  • Alejandro Torres
    July 17, 2007 at 2:08 am
    Use the Connect function on both splines (they must be editable not primitives and then use an Extrude nurbs object with a low height value.
    It shouldn’t be hard to do so.
    Regards
    Alejandro
  • Joseph M. morgan
    July 17, 2007 at 2:16 am
    Having absolutely no patience… I kept trying stuff ( I’m a “happy accident” master 🙂 ), and put them in a loft nurbs and turned on the “Loop” checkbox.
    Though it seems to have worked (at least with the simple primitives), am I getting myself into trouble?
    Joe
  • Joseph M. morgan
    July 17, 2007 at 2:30 am
    That works too (See my post (accidentally to you) using Loft Nurbs and the Loop option)… except, two corners are capped off. How to I prevent that?
    Is using the connect with extrude better/worse that loft with loop?
    Joe
  • Alejandro Torres
    July 17, 2007 at 3:28 am
    I think it really depends on the spline, I personally prefer the extrude NURBS as it makes neater polys. You can use whatever suites you and if you have trouble with some edges try making the extrude/loft editable and arrange it via the modeling tools. R10 has a great tool for closing holes in a poly (I don’t think R9.6 has it).
    Hope it helps and you can keep on, ohh and by the way, on your other post (the one on the lights), perhaps you could get a little bit into expresso, it’s really not that difficult but mograph is definitely worth it (not just in this case it’s overall a great tool). Mylenium (here on the creative cow) has some great tutorials on MoGraph and the last one (the sound effector one #11) has some expresso on it that can help you agetting a general idea. You can also try http://www.c4dcafe.com, great tutorials in there.
    Regards
    Alejandro
