Activity Forums Adobe After Effects Expressions Paint effect stroke shape to Shape layer shape via script
  • Paint effect stroke shape to Shape layer shape via script
    Posted by Juanluis Vich on April 19, 2018 at 12:15 am
    Hi!
    IWhen working with paint stroke effect, I usually like to paste the path info to a shape layer’s path (as easy as go to the paint stroke path, then copy, and go to the shape layer path and paste.
    BUT I’m trying to automate that a bit via scripting, so when the script is executed, it automatically copies that info of the stroke path value and paste into the shape layer’s path value.
    I was reading a bit here at the redefinery site but Im totally stuck, because I don’t know how to use the stored data in the paintStroke array he mentions about, and paste into the shapePathData of a new created shape
    (this is the code from the Redefinery article, just in case you can’t click at the link)
    // given:
    // layer = Layer object, and the layer can have effects applied
    var selectedPaintBrushes = new Array(); // Store brush strokes in an array
    var effects = layer.property("Effects"); // Look for layers that can have effects
    if (effects !== null)
    var effect, paintStrokes, paintStroke;
    // Iterate over all effects on the layer
    for (var i = 1; i <= effects.numProperties; i++)
    effect = effects.property(i);
    if (effect.matchName === "ADBE Paint") // Look for Paint effects
    // Get PropertyGroup containing the strokes
    paintStrokes = effect.property("ADBE Paint Group");
    // Iterate over the brush strokes
    for (var j = 1; j <= paintStrokes.numProperties; j++)
    // Store only selected strokes in the array
    paintStroke = paintStrokes.property(j);
    if (paintStroke.selected)
    selectedPaintBrushes[selectedPaintBrushes.length] = paintStroke;
    // The selectedPaintBrushes array now contains the list of selected paint brush strokes
    // in top-to-bottom order
    do you have any ideas?
    thanks!
    Juanluis Vich replied 8 years, 4 months ago 2 Members · 2 Replies
  • Santi Agustí
    April 25, 2018 at 5:10 am
    mmm
    this post recalls me to an old quick adaptation I made of the exquisite Redefinery Script that converted masks to shapes, to make it work with paint brushes and shape layers. As I was in an animation project rush and I needed a quick tool for converting brushes paths to shape layers, I only could scratch the surface of the script, and I ended up copy-pasting the paths by hand.
    The thing is, having this adapted script as a basis, maybe you can do the copypaste via scripting, copying from the brush path property array to the newly shape paths generated.
    Im totally lost on that, so I can help more than that, I don’t know how to go from the original paths, store their values, and paste on the duplicated paths in the shape layer ☹
    Making that work would be a really handy tool I think! Any advice?
    here is the quick script you can start from. Now it goes thru all the brushes of a solid, and makes a duplicated of them on a newly created shape layer, buuuuuuut they are empty (is handy to recreate the hierarchy btw)
    // quick and awufully adapted code from the original rd_MasksToShapes from the great https://www.redefinery.com/ae/rd_scripts/
    app.beginUndoGroup("duplicate paintGroups to shape layer groups");
    var activeComp = app.project.activeItem;
    var myLayers = activeComp.selectedLayers[0];
    var paintGroup = myLayers.property("ADBE Effect Parade").property("ADBE Paint").property("ADBE Paint Group");
    // Create an empty shape layer
    var suffix = " the Shape";
    var shapeLayer = activeComp.layers.addShape();
    shapeLayer.name = myLayers.name.substr(0,31-suffix.length) + suffix;
    shapeLayer.moveBefore(myLayers);
    var shapeLayerContents = shapeLayer.property("ADBE Root Vectors Group");
    var shapeGroup = shapeLayerContents; //.addProperty("ADBE Vector Group");
    // Iterate over the paints layer's paints, converting their paths to shape paths
    for (var m=1; m<=paintGroup.numProperties; m++)
    // for (var m=1; m<=paintGroup.numProperties; m++)
    // Get paint info
    paint = paintGroup.property(m);
    paintShape = paintGroup.property("ADBE Paint Shape");
    // Create new shape path using paint info
    shapePathGroup = shapeGroup.addProperty("ADBE Vector Shape - Group");
    shapePathGroup.name = paint.name;
    shapePath = shapePathGroup.property("ADBE Vector Shape");
    app.endUndoGroup();
    Sorry I can’t help more, but as your question was something similar to what I did, maybe is useful as a start until some real scripting expert can drive you onto a better direction ????
  • Juanluis Vich
    April 27, 2018 at 1:04 pm
    thanks!
    I have no idea about how to achieve the copypaste thing via scripting, but as a hierarchy replicator as you said, it works 😀
