Activity › Forums › Maxon Cinema 4D › Paint brush Bristles
  • Shawn Smith
    February 3, 2010 at 2:20 pm
    Hi Randy I have a quick question if I don’t want my text to have that flat beveled look when I extrude it, so should I loft the splines to give it more of a tube or puffier look?
  • Randy Johnson
    February 3, 2010 at 2:37 pm
    It really depends on the font and the look you want. The extrude nurbs have some nice clean beveling options in the caps tab (for beveling you almost always need to enable the “constrain” option) However IF your font allows it using a sweep nurbs with your text can give nice results. Make sure they are in the correct order. Should look like this:
    Sweep Nurbs
    -Shape (square, circle ect.)
    -Text
    This will however give you two sided letters so you will have to work on your spline a bit. There is a actually a tutorial about just this at the c4d cafe. I have not seen it but 3D Kiwi is very good and does not skip a step in his tutorials. The tutorial is free but you need to sign up for it… its well worth the time there are loads of excellent tutorials.
    https://www.c4dcafe.com/ipb/index.php?/files/file/736-mospline-animated-text/
  • Shawn Smith
    February 3, 2010 at 3:00 pm
    Thanks again Randy will try it later and send you what I’ve done.
  • Shawn Smith
    February 4, 2010 at 4:12 am
    Hi Randy sorry to be a bother but when I go to Hair > Edit Hair >convert from spline I can not see hair when I render. Any answers for this?
  • Randy Johnson
    February 4, 2010 at 7:54 am
    You need to apply the hair material.
    Materials: File: Hair Material
    /randy
  • Shawn Smith
    February 4, 2010 at 5:51 pm
    Thanks Randy now with the reverse hair do I go into spline and reverse
    it through edit spline in Structure tab
  • Randy Johnson
    February 5, 2010 at 7:12 am
    yea that should do it. select the poinats and reverse sequence.
    /randy
  • Shawn Smith
    February 5, 2010 at 2:28 pm
    I want to move the hair object around for placement but it’s locked in that one spot. I’ve tried everything I could think of. What am I doing wrong?
  • Shawn Smith
    February 9, 2010 at 12:58 pm
    I want to move the hair object around for placement but it’s locked in that one spot any ideas?
  • Randy Johnson
    February 9, 2010 at 1:04 pm
    Place the Hair object and the refrence object in a NULL and move that.
    /randy
Page 2 of 3
