Activity › Forums › Adobe After Effects › Paint Bleed/Water Effect
  • Jerzy Drozda jr
    December 9, 2007 at 5:25 pm
    I think (I almost sure) that both of these clips was recorded with a camera. The color Ink was simply colorized in AE with a layer and blending mode set to hue or color.
    Both are pretty possible to do i think using a particle system, but if you consider time needed to set this up and render it, it’s probably better to just get a tank and some ink and just record it with a camera.
    maltaannon.com – Free After Effects Video Tutorials and more
  • Steve Roberts
    December 9, 2007 at 7:45 pm
    Yes, that kind of thing is nearly always shot in a tank.
    If you want to attempt to do something realistic in CG, you need a fluid simulation app such as Realflow, but that takes a fair bit of of money (if I recall) and a lot of horsepower to get renders out at a non-glacial pace. Since it’s so powerful, it also takes a fair bit of tweaking to get what you want. But it’s very realistic. But … I don’t even know if it’ll mix two fluids. Mr. Useful, that’s me. 😉
    The “billowing smoke” look might be possible. You might be able to get something by using a regular 3D app using some kind of particle/hypervoxel simulation, or maybe with particle Illusion or Particular in AE.
  • Brennan Wright
    December 9, 2007 at 10:39 pm
    you could just buy it too….
  • Nicholas Toth
    December 10, 2007 at 2:51 pm
    Blender has a half decent fluid simulator. And its free.
    You just have to learn it.
    Artbeats has some great stuff. What you pay is what you get!
  • Tornike Gelashvili
    December 10, 2007 at 3:10 pm
    thank you all
  • Sabin Arditty
    December 11, 2007 at 9:53 pm
    sorry this is a little late, but Andrew Kramer has some pre matted ‘ink flows’/’paint drops’ in his Riot Gear dvd on videocopilot.net I have used these effects from time to time. they come in quite handy.
    -Sabin
    December 12, 2007 at 2:34 am
    Yes, I know Riot Gear. I actually do use it, but I just though about the way it could be made, ’cause there are only a few of them on the Riot Gear DVD and not much on the web.
