Activity › Forums › Apple Final Cut Pro Legacy › Paging Mr. Natress, Mr. Natress…
Posted by Will Macneil on May 8, 2005 at 8:25 pmHi Graeme,
I’ve got some digibeta footage (PAL, 16:9) I want to give a progressive look. Any suggestions for this with the G Film Plugin or Standards Converter?
Solie Swan replied 21 years, 4 months ago 5 Members · 6 Replies -
Peter Wiggins
May 8, 2005 at 10:11 pmWill,
I was using his ‘smart deinterlace’ for two and a half weeks for the BBC on the snooker coverage.
Graeme Nattress
May 9, 2005 at 12:46 amYes, the Film Effects package has all the stuff you need in it. As Peter points out, the smart-deinterlace is a nice one, and should work great as it did for him on the Snooker.
Graeme
– http://www.nattress.com – Film Effects for FCP
Anders Haavie
May 9, 2005 at 10:08 amI use revisionfx deinterlacing. Works absolutely great. I have no idea if it works better or worse than the stuff already mentioned. Doesn’t cost very much either.
https://www.revisionfx.com/rsfk.htm
Anders
Graeme Nattress
May 9, 2005 at 11:04 amWill – do you have an earlier version? If so drop me an email and I’ll send 2.1 your way fast.
Graeme
Solie Swan
May 9, 2005 at 2:05 pmI happen to have both – the plus with RSMB is that it works in both AE and FCP but for $10.00 more you get a whole lot more in the Nattress plugin but it is limited to FCP.
