Activity Forums Web Design (WordPress, Joomla, etc.) Pagination without using a database or cms?
  • Pagination without using a database or cms?
    Posted by Jessica Chapman on October 11, 2011 at 11:59 pm
    Hi guys!
    I’m having a hard time trying to get my head around the best way to have pagination on a static html website (with php includes). Unfortunately I don’t have enough time to learn how to use a database or cms for this website – it needs to finished soon for school. 🙁
    – There are 80 student profiles.
    – I am using the <?php include ‘example.php’?> command to load the header and footer in each student page.
    – Each student page has it’s own jquery slideshow, along with some written content.
    On each student page, I would like to have pagination. Similar to this approach would be really awesome:
    https://tympanus.net/codrops/2009/11/17/jpaginate-a-fancy-jquery-pagination-plugin/
    But really, I’m not fussed, just as long as I can have some numbers which link to each page through a script or something.
    Basically, I want an easier approach than having to manually link every button on each student profile page to go to the next/previous student pages.
    Does anyone have any ideas/suggestions how I could go about doing this?
    I would be so very very grateful for any help! 😀
    Demetri Tashie replied 14 years, 9 months ago 3 Members · 2 Replies
  • Curtis Thompson
    October 20, 2011 at 9:08 pm
    hello…
    any pagination will need to be aware of a start and end number to render itself – if you knew that or could render that in a separate page, you could do an iframe (not so glamorous) or a php include in the specific pages that shows the page controls and numbers….
    hard to give a more detailed suggestion w/o knowing more about your project…
    sitruc
  • Demetri Tashie
    November 19, 2011 at 4:04 am
    hi jessica,
    if this response is not too late, i have some suggestions. i don’t see why this can’t be done with a combination of php includes and javascript.
    it is hard to tell from your description if this is what you meant, but i would certainly consider the student’s pages being includes also. then through javascript you can have the button clicks load in a new, and correct, student page, as well as change the copy on the home page to take care of your ‘pagination’.
    you can see a real simple working example here
    the main html page just has 5 divs:
    a header and footer div which load in content via php includes
    there is a div to contain the ‘page number’/pagination information
    a div for the actual page content to load into via php includes,
    and a div for the buttons
    some pretty simple javascript in the header changes the contnet div and the page number div via innerHTML
    there are other ways, but i just made an array to hold all the page content incudes ( this would be your student page information)
    and just as Curtis suggests, there is a variable there which is used to keep track of/be aware of what page is laoding in/ what page number it is. then going to a next or previous student page would be easy.
    this is the javascript i used. i didn’t bother to put any limits on the button clicks to keep them from going beyond their bounds, and i only have 3 actual pages in the array – therefor you will see ‘undefined’ in the content area div for pages missing from the array.
    var i=1;
    var myArray= new Array();
    myArray[1]="<?include('main1.php');?>";
    myArray[2]="<?include('main2.php');?>";
    myArray[3]="<?include('main3.php');?>";
    function next()
    ++i;
    document.getElementById("pageNum").innerHTML= "Page "+i+""
    document.getElementById("main").innerHTML= myArray[i];
    function prev()
    --i;
    anyway, i hope this helps or gives you ideas opn how you can make it work for you. if you need anything exaplained, just ask.
