Activity › Forums › DaVinci Resolve › Pages Tab not showing in Davinci Resolve (Macbook Pro Retina)
  • Robbie Carman
    August 27, 2014 at 7:29 pm
    change your display settings to “more space”
    Robbie Carman
    Colorist and Author
    My Books
    Online Training
    Twitter
    Blog
    Mixing Light Powered By The Tao Of Color
  • Don Eitner
    September 14, 2014 at 8:55 am
    On the View menu go down to User Interface Layout and then click Show Window Frame. You can then resize (i.e. maximize) the window using the standard OSX “green circle” button at upper-left of the window and you should see the MEDIA, EDIT, COLOR and DELIVER buttons across the bottom.
    I had the same issue here on a monitor which is only 1600×900. Unfortunately it seems you need to click the green circle/maximize button each time you launch, though you should not need to seek out and click Show Window Frame each time.
    Don Eitner
  • Aaron Budiman
    September 14, 2014 at 8:58 am
    Thank you very much for the tip Don! 🙂
  • Aaron Budiman
    September 14, 2014 at 9:00 am
    Thanks a lot Robbie! 🙂
  • Larry Herbst
    March 24, 2015 at 8:09 am
    Thank you for this.
    It amazes me that a software developer can release a product (even a free one, and yes I’m grateful) where a certain significant population of users will immediately crash right into a wall on first use. I spent an hour just trying to figure out where all the functionality was, downloaded the user manual (which of course just says look, the pages tab is right there, but it’s not) and found myself ready to write off the whole project.
    I’m already expecting Resolve to be a painful learning curve, since they hid the keys to the kingdom right from the get-go, and obviously are oblivious to how the most basic functions might not be readily apparent.
    Truly, if you hadn’t laid out simple step-by-step instructions, I’d have given up and gone to bed.
    I thank you sir.
  • Josh Steinbauer
    May 27, 2015 at 5:07 pm
    yeah, had the exact same infuriating problem. watching all these tutorials, but had no way to get started because my screen didn’t have the same tools. bad form, Black Magic.
