  • Posted by Terry Moore on April 23, 2007 at 11:00 pm
    I have a logo that I want to page peel on to the screen. When I apply the Peel effect to the beginning of the clip, the logo does not peel and I have no control of the effect. When I apply the effect to the END of the logo clip, it peels perfectly. Any suggestions?
    Terry Moore replied 19 years, 5 months ago 2 Members · 2 Replies
  • Andy Mees
    April 24, 2007 at 12:27 am
    thats because by default Page Peel will peel off the outgoing clip …. you need to tell the transition to act in reverse:
    add the transition to the start of the clip
    select it and press enter to load it into the viewe
    directly to th eright of th esliders that control the start and end percentage of completion for the transtion, you will see a small rectangukar gray button containing a transition icon and a small right pointing arrow within
    toggle that button and you will see the arrow changes to point left, that now indicates that the transition will work in reverse
    see if that works now
  • Terry Moore
    April 24, 2007 at 2:55 pm
    Thank you for your help!
