Activity › Forums › Apple Motion › Page Peel
Page Peel
Posted by Stephen Smith on February 10, 2009 at 9:02 pmI’m looking for a plug-in that creates a page peel for Motion. One that works with Alpha Channels and lets you animate the page curl so you can choose to not let it peel all the way. Basically, one that operates like the AE page curl. And I’m looking for an answer other then “use AE then”. Thanks.
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Albert Oconnor replied 13 years, 8 months ago 6 Members · 12 Replies -
Stephen Smith
March 6, 2009 at 12:59 amStink…I was looking for an answer other then silence.
Chad Lindsey
November 6, 2009 at 7:04 pmAny luck on finding this Stephen?
I have searching aimlessly and have not found anything yet.Thanks, Chad
Stephen Smith
November 6, 2009 at 7:45 pmSorry, I have not had any luck. I was hoping that that would be included with Motion 4, but no dice. If you find anything let me know.
Check out the Graphics Demo Reel I did.
Check out my Motion Tutorials
Alex Kaloostian
February 21, 2010 at 12:58 amHow about using the Page Peel transition in FCP, then exporting a MOV with an alpha channel?
“I’m Alex Kaloostian, and I approve this message.”
Stephen Smith
February 22, 2010 at 4:38 pmThanks Alex, but for me, the Page Peel transition in FCP won’t let you place an object such as a .psd with an alpha channel in its back. If you do, it turns the Alpha Channel black. Hopefully Motion 5 will have a page peel much like After Effects. Just my two cents.
Steve Delasantos
October 13, 2010 at 6:48 pmWhat about using the CURL filter in FCP? That’s pretty controllable.
Stephen Smith
October 14, 2010 at 3:35 pmSteve,
The Curl filter is really cool and I didn’t know about it. However, it will not work with alpha channels as well. Instead of making a part of an image see through where the alpha channel is it makes it black. If you wanted to flip though an old book with rough (torn) edges it would be black on the edge whereas in After Effects it will be transparent.Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Steve Delasantos
October 15, 2010 at 12:48 pmThat’s right, I forgot about it not working with the alpha channel. Oh well, worth a try. Good luck!
Steve
Stephen Smith
October 15, 2010 at 6:20 pmLooks like I’ll keep using After Effects for my page peels.
Stephen Smith
Francis Baconnaise
September 23, 2012 at 3:17 amI have an idea…
What if you use the curl feature in FCP, duplicate your media and stack them on V2 and V3, leaving V1 empty. Then with the copy on V2, play with any of the color, gamma, or brightness & contrast controls until you have what is essentially an alpha channel. Then set the composite mode on the V3 copy to Travel Matte Luma.
The V3 clip will use what lies directly beneath it as a Matte. White shows, black is transparent and passes through to whatever lies on V1.
