Activity Forums Compression Techniques Padding File Length in MPEG Streams
  • Padding File Length in MPEG Streams
    Posted by Tod Hopkins on May 3, 2012 at 2:27 pm
    Can any compressor produce synchronous, multiplexed MPEG files (program or transport) with identical file lengths, that is “padded” to be exactly the same length to the bit? I believe this can be done with Pixel Tools but I don’t know how and don’t have access. Can other compressors produce such padded files directly? Are there any tools that might help me add pad to an existing file?
    I currently use TMPEGenc, which has always done a great job for me, but as far as I can tell, it can’t do this. Three files of identical length with identical CBR settings don’t come out the same length to the bit.
    Cheers,
    tod
    Tod Hopkins
    Hillmann & Carr Inc.
    Washington, DC
    Tod Hopkins replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
