Activity › Forums › Apple Final Cut Pro Legacy › p2+sequence settings
Posted by Airto Jackson on August 29, 2006 at 5:35 pmDoes anyone have any sequence setting suggestions for imported p2 files shot at 960 x 720 and 23.98fps? Your help would be very much appreciated, thanks.
Shane Ross replied 19 years, 10 months ago 2 Members · 5 Replies -
Airto Jackson
August 29, 2006 at 7:16 pmShane,
Thanks for replying. I’ll try that out. I have one more question if you’ve got a sec. I have some rendered files that when I view on my monitor everything looks great, but after I’ve viewed a dvd version I notice the aspect ratio jumps at the edge of my screen. I looked on the timeline and there are no cuts at that point. So my question is do you know why this might be. Thanks so much for your time.
Shane Ross
August 29, 2006 at 8:48 pmCan you explain that better. I am not getting what you mean by ‘jumps at the edge of my screen.’
Also, how are you monitoring your timeline? Computer monitor, right?
Shane
Littlefrog Post
http://www.lfhd.net -
Airto Jackson
August 31, 2006 at 4:50 pmLet’s see how can I explain it. When I watch the timelined version on the computer monitor everything is fine. The aspect ratios are all correct. But when I burn it to a dvd and watch it on a regular television the sides of the footage work fine then out of no where they jump in about an inch. After that it stays in that aspect ratio for most of the remaining video.
Thanks for your help.
Shane Ross
August 31, 2006 at 9:13 pmI don’t know what to say…I have never experienced such a thing. My DVD burns are all good.
Shane
Littlefrog Post
http://www.lfhd.net
