Activity › Forums › Adobe Premiere Pro › P2/mxf support?
P2/mxf support?
Posted by Shane Dillon on November 21, 2006 at 6:37 pmIs there anyway to use P2 footage in a Premiere project?
Michael Hurwicz replied 19 years, 9 months ago 7 Members · 6 Replies -
Tim Kolb
November 21, 2006 at 7:55 pmCineForm imports it through Aspect or Prospect…
Serious Magic’s plugin should also handle it on the way in…
TimK,
Director,
Kolb Productions,Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Craig Howard
November 21, 2006 at 8:00 pmYes but it requires additional software.
I use
1 – DVCProHD Encoder (Serious Magic) and
2 – CineformApect HD.
Both for different reasons.
Simplest is #1. This “encodes” MXF files as avis. eg DVCPro50 from mxf to avi. Use directly in the PPRO project.
The other #2 – has a app within it – ‘HDLink” that does the same but also is a plug in for Prempro2 that enables editing HD as Cineform avis (intermediates) in Cineform Aspect Projects (presets).
Two versions of Serious Magic product – a standalone or DVRackHD which contains the encoder. (ie $195 or $500)
Craig Howard
Shooter Film Company
Auckland
New ZealandPremiere Pro 2.0
Majorasshole
November 26, 2006 at 11:54 amI am currently using Raylight to convert mxf files to avi files.
I can then use them to edit in Premiere Pro or After Effects. -
Lauralouface
November 27, 2006 at 6:06 pmI was looking at Raylight as a way of converting my mxf files to edit in Premiere Pro – I was wondering if you have to use the p2 card or have the slot to use this program? What we did was dump all our footage from the p2 card to an external hard drive, so that is where all my mxf files are coming from…
-Laura
Michael Hurwicz
December 11, 2006 at 5:10 amRaylight can convert MXF files copied from the P2 card to a local hard disk. You do not have to use the P2 card or have the slot to use Raylight. You can download a free demo of Raylight to try this out:
https://www.dvfilm.com/raylight/index.htm
