Activity › Forums › Panasonic Cameras › P2CMS database issue
  • P2CMS database issue
    Posted by Andrew Johnstone on September 20, 2013 at 12:39 pm
    P2CMS does not seem to recognise an exiting database.
    Now I do not regularly use this to ingest content to FCP, preferring to make a hard copy of the “Contents” and “lastclip” files to an external drive and then ingesting data using “Log and capture” in FCP, but I did use P2 CMS when I first got my P2 system.
    I have all the data file (and of course I now have the Quicktime files in the FCP ingest archive/scratch disc) but if my database is corrupted, is there another way to read them without the “last clip” file?
    I am going to have a look to see if Adobe Premier can open the files natively…
    Thanks for any help.
    Andy Johnstone
    Wild Dog Limited
    film & multimedia production
    http://www.wilddogworld.com
    Martin Rose replied 13 years ago 2 Members · 1 Reply
  • Martin Rose
    September 24, 2013 at 10:14 pm
    You could try just creating a new database and then see if P2CMS will read the clips.
    Basically I never used the ingest function anyway, Just read the cards or folder, select which clips you want and then export to a new folder.
    Alternatively you could try P2 viewer plus
    https://pro-av.panasonic.net/en/sales_o/p2/p2viewerplus/
    Martin
