Activity Forums Panasonic Cameras P2CMS clips out of order when imported
  • P2CMS clips out of order when imported
    Posted by Jacinto Astiazaran on January 18, 2010 at 12:09 am
    I have a Panasonic HPX-170 and every time i import footage through P2CMS the clips appear out of order, so i have to click around to the clips i want. how can i avoid this so that everything appears in its alphanumeric order??
    thanks.
    John Fishback replied 16 years, 7 months ago 2 Members · 1 Reply
  • John Fishback
    January 19, 2010 at 9:35 pm
    I’ve never used P2CMS, but if it’s similar to other programs you might be able to select how the data is sorted by clicking on the column name. See if that works.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
