Activity Forums Panasonic Cameras P2 workflow out in the field
  • John Mckeown
    July 28, 2008 at 1:14 pm
    Hi
    When you use the Fusion F2 in the field on a MacBook Pro, do use a firewire hub to connect the HVX-200, as your only Firewire 400 port is in use by the F2?
    Sorry if this is a dumb question. I’m just wondering which way to go with field acquisition.
    Many thanks in advance.
    John McKeown
  • Jeremy Garchow
    July 28, 2008 at 4:23 pm
    [John McKeown] “When you use the Fusion F2 in the field on a MacBook Pro, do use a firewire hub to connect the HVX-200, as your only Firewire 400 port is in use by the F2? “
    I don’t connect the HVX through firewire. The Firewire used by the F2 is just for power only. It does not take up any bandwidth. If you need to connect through firewire, you can get a fw800 to fw400 cable and connect your camera that way.
    Make sense?
    Jeremy
  • John Mckeown
    July 28, 2008 at 10:09 pm
    Thanks for the simple answer to my dumb question.
    Cheers
  • Jeremy Garchow
    July 29, 2008 at 1:59 am
    [John McKeown] “Thanks for the simple answer to my dumb question. “
    No worries, John. There’s no dumb questions about information that you don’t know. That’s why the cow is here.
    Jeremy
Page 2 of 2
