Activity › Forums › Panasonic Cameras › P2 Workflow for TV series
Posted by Steve Gruskin on August 19, 2008 at 2:15 amWe are about to embark on the production of 19 episodes of a strip series for a major cable network. We plan to shoot in DVCPro50 with HPX and HVX cameras. We are including a “P2 Wrangler/Logger” on location to copy the cards and import them into FCP as they are used. There will be redundancy in this process so we’re not worried about that. The issue is that we have a deliverable requirement for camera tapes, and if we make tapes using stringouts of the footage taken from the P2 cards, the timecode on the tapes will not match the timcode on our edl’s. Any thoughts? Thanks!
Steve Gruskin replied 18 years ago 6 Members · 12 Replies -
Shane Ross
August 19, 2008 at 3:12 amOne thought would be that if you are required to deliver camera master tapes with TC that corresponds with your project, then you should be shooting with cameras that record tape. Or you are going to have to go through the ridiculous redundant and time consuming and non-cost saving step of importing your footage, stringing it out in your NLE, outputting to tape, then recapturing that tape. That will be one way that you can make camera masters with matching timecode. Another would be to output your masters to tape later, making the sequence match your footage TC (as long as you don’t do time of day), black a tape to match, then output.
Still, you aren’t saving money in the long run…and you definately aren’t saving time. Either petition the network to accept the tapeless format or shoot to tape.
Shane
Read my blog, Little Frog in High Def -
Steve Gruskin
August 19, 2008 at 3:42 amThanks Shane. We did have that thought, of course. In our case we’re making 19 half hour shows in 3 months and speed at the front of the production cycle is important. Shooting with the HPX and HVX cameras will be good for our production. We don’t mind having to dub stringouts to tape, it’s just time later when we have it. It’s very frustrating – the cable networks push like crazy for lower production costs, but are not willing to let us deliver in the most efficient way. We’re backing up our completed projects including all media to a high capacity tape drive so we could restore it to a local hard drive in it’s entirety for future edits, but I don’t think our network will accept that as a solution. We’re not working with DCI on this project so there is no tape library/stock footage angle, it’s just this maddening transitional time where the capture/ingest technology has surpassed the client’s legacy tape library system.
By the way, I read your article on P2 work flow and enjoyed it very much!
Shane Ross
August 19, 2008 at 4:09 amThey won’t accept LTO or DLT data tape? Shame, many places don’t. Yeah, we are also getting the “give us an HD show at SD prices…or sub SD prices. Oh, but keep the same workflow…”
Shane
John Twigt
August 19, 2008 at 11:44 amI understand your predicament here, I suppose the time isn’t there to first copy the P2 to tape and then ingest tapes (instead p2 cards) ? Another solution might be getting a Panasonic AJ-HPM110 or AJ-HPS1500 (P2 player/recorders) with a TC out and playing these to tape then ingest P2 in NLE. This would probably mean you’ll need twice the amount of P2 cards, (thus a lot of money to get the cards en recorders) since you’ll at least double (probably triple) the time to free up your cards for shooting.
The I can only think of ‘recreating’ the P2 cards in your NLE by putting all the shots in shooting order (if you didn’t shoot in free-running TC or delete a lot of clips on site)in a sequence an dump these to tapes. (also a lot room for errors here).
Is timecode consistency really important for your client? I mean will they use your logfiles or will they recut your sequences ? Otherwise timecode is maybe not such a big issue for them….
Good luck with all this
John Twigt
Workstation BV, Amsterdam
The Netherlands
http://www.workstation.nl -
John Twigt
August 19, 2008 at 11:52 amMe again, I just noticed that you’re not shooting HD, so the panasonic AJ-SPD850 will also work (again a P2 recorder/player but no HD on this), and in SD time maybe an ever bigger issue (playout time vs. P2 ingesting). But I thought maybe it helps anyway, demo version for sale here
John Twigt
The Netherlands
Adam Smith
August 19, 2008 at 4:54 pm[John Twigt] “I suppose the time isn’t there to first copy the P2 to tape and then ingest tapes (instead p2 cards) ? Another solution might be getting a Panasonic AJ-HPM110 or AJ-HPS1500 (P2 player/recorders) with a TC out and playing these to tape then ingest P2 in NLE.”
Not to derail the discussion, but is it possible to import the MXF as normal and at a later date rebuild the project from tape clones?
Obviously this would be dependent on the edit system but I’m working on a 5 year old Avid Meridian, I’m still a noob with the FCP rig at home, and I’m still learning about all the potential P2 workflows.
Video Photographer / Avid & Final Cut Editor -
John Twigt
August 19, 2008 at 5:16 pmI’ve no experience with Avid (old or new) just some with FCP and extensively with Media100Hd and 844/x systems. But rebuilding a project from tape is impossible on a file level, I think. What would be possible is to redigitize a timeline (edit) from tapes, if the original ingest (or digitizing) was done with proper timecoding and reel naming. In the case of redigitizing from tape a timeline made with P2 ingested clips, the relationship (timecode wise) between the P2 footage and the tape copies must be flawless, otherwise you’re doooooomed.
Hope this helped,
John Twigt
The Netherlands
Jeremy Garchow
August 19, 2008 at 6:22 pm[John Twigt] “the relationship (timecode wise) between the P2 footage and the tape copies must be flawless, otherwise you’re doooooomed.”
Not only that, but if you record in anything other than 60 or 50 fps, you won’t be able to match back to your 25pn or 24pn p2 footage as you will lose all of the flagged frame info when stringing back out to tape.
Jeremy
Steve Gruskin
August 20, 2008 at 1:31 amThanks for the suggestions. We’re going to try to persuade our network to accept the tape backup solution. The AJ-HPM110 is a good potential solution, but is costly. We’re planning to copy the MXF data to a drive for file safety before we import the P2 cards into FCP. Can we use that data to reconstruct the cards later and possibly transfer to tape at a later date? This will still be costly, but will not tie up resources on location. Thanks!
Jeremy Garchow
August 20, 2008 at 2:42 am[Steve Gruskin] “Can we use that data to reconstruct the cards later and possibly transfer to tape at a later date?”
As long as you keep the same structure. Most definitely.
Jeremy
