Activity Forums Panasonic Cameras P2 viewer alternatives?
  • P2 viewer alternatives?
    Posted by Christopher Walsh on September 12, 2006 at 4:23 pm
    I haven’t been able to get the Panasonic P2 viewer to load/show me any of the clips I copied from cards to my HDD. I copied the entire folders via Windows Explorer from the cards to new individual directories on my laptop’s external drives. The viewer was able to show me the clips from the card, but when I specified these new HDD directories as “virtual P2 drives”, the viewer found no clips. I copied everything off the cards (CONTENTS folder as well as lastclip.txt.)
    I uninstalled, reinstalled, pointed to different folders (the clips import fine into various Avid systems), and at this point am just wondering if there are any other options for P2 mxf file viewing? I’m most interested in viewing, since I’m not cutting off my laptop this go round.
    I’m giving Raylight a shot right now – but are there any direct viewing options (raylight seems to be making .avi proxies essentially)?
    Izoneguy replied 20 years ago 2 Members · 1 Reply
  • Izoneguy
    September 13, 2006 at 4:57 am
    “I copied the entire folders via Windows Explorer from the cards to new individual directories on my laptop’s external drives.”
    Just make sure the CONTENTS & LASTCLIP.txt do not go down two levels….
    It should be >P2_CARD_FOLDER_01>CONTENTS & LASTCLIP.txt
    Then in P2 viewer you point the finder to P2_CARD_FOLDER_01
    If you have something like this >ORIGINAL_FOLDER>P2_CARD_FOLDER_01>CONTENTS & LASTCLIP.txt
    that could be a problem….
    the fact you can see the P2 card means everthing is installed and working….
    And make sure your drive is mounted properly….I have seen stranger things…
    And do not mess around with adding or deleting files in the CONTENTS folder!!
    Good luck
