Activity › Forums › Apple Final Cut Pro Legacy › P2 upside down
P2 upside down
Posted by Simon Webb on May 24, 2007 at 9:27 pmOkay, this is an odd one. I’m importing P2 footage but all of the shots on the P2 Store are upside down. Anyone know what I can do short of flipping every shot in the timeline?
Jerry Hofmann replied 19 years, 3 months ago 8 Members · 9 Replies -
Jeremy Garchow
May 24, 2007 at 9:36 pmSounds like they shot with a redrock 35mm lens adapter or similiar. Unfortunately, that’s the way it’s recorded. You need to flip every shot.
Jeremy
Russell Lasson
May 24, 2007 at 9:38 pmIt was mostly likely shot with the redrock lens adaptor. I’ve tried to figure out a way to use QuickTime to just read the frames upside down, but I couldn’t get it to stay upside down in FCP.
You could edit with your monitor upside down 🙂
-Russ
Chris Borjis
May 24, 2007 at 9:56 pmThis kinda reminds me of the .tif file format bug that makes imported sequences sometimes show as upside down.
Todd Sali
May 24, 2007 at 10:08 pmWhat I do is drop all clips into a timeline , add flip filter to one, set to vert and hor, copy clip. select all other clips, paste attributes for filters. drag all those new clips to a bin and delete the originals. then you can edit as if they were never flipped. (though the thumbnails are still flipped)
cheers,
todd -
Todd Sali
May 24, 2007 at 10:35 pmNot on a MacPro (3Ghz), at least with my experience. No green bar.
Cheers,
Todd -
Steve Wargo
May 25, 2007 at 6:14 amTurn your deck upside down and re-import.
Steve Wargo
Tempe, ArizonaIt’s a dry heat!
Leia Vogelle
May 25, 2007 at 11:20 amI have never worked with P2 footage, so maybe the following won’t work with P2, but with a generic QT file, you can use QTPRO to turn the clip upside down, save the change, then import/reimport to FCP. Oddly enough, the clip appears to be not upside down when viewed from the browser, but once in the timeline, it IS upside down!
Hope this helps!
Leia V
London, UK -
Jerry Hofmann
May 25, 2007 at 2:30 pmLOL…The dry heat has gotten to you man…
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
