Activity Forums Avid Media Composer P2 trouble in Xpress Pro
  • P2 trouble in Xpress Pro
    Posted by Brian Wiebe on August 11, 2008 at 7:51 pm
    I have a mac with media composer 2.7 at home, and a I recently acquired a Panasonic HVX 200, and have not had any problems, so far.
    Where I work has a PC with Xpress Pro 5.7.7 loaded on it. I am attempting to use HD footage on this computer for the first time and I am running into some problems:
    I am in a 720p/59.94 project (I shot in 720p/60). I import the P2 clips to bin then import P2 to media and everything seems to function fine, but as soon as I import media from a second card–the first cards goes offline and/or reverts to a “Virtual” drive (where the P2 clips originated, but not to the consolidated media).
    I should probably add that I am not pulling the media of actual P2 cards, I am pulling it off a hard drive (I used HD Log to copy onto the hard drive).
    I have a feeling I am missing something simple, but I also don’t know if this is a known issue with this particular incarnation of Xpress Pro. Any ideas?
    David Braswell replied 18 years, 1 month ago 2 Members · 3 Replies
  • David Braswell
    August 11, 2008 at 8:26 pm
    This was covered fairly extensively in another forum (DMN, I think). It happens here (MCA 2.8.3) as well. Highlights of solution are:
    1-Have no sequences and only the one bin you’re importing to open.
    2-You can usually only import media one time into a bin.
    3-If you have spanned clips, import all clips before importing media.
  • Brian Wiebe
    August 12, 2008 at 4:57 pm
    Thank you! Worked like a charm.
  • David Braswell
    August 12, 2008 at 7:05 pm
    Great to hear! I’m looking forward to continuing improvements in Avid’s P2 workflow.
