Activity Forums Panasonic Cameras P2 to Mov file conversion application
  • P2 to Mov file conversion application
    Posted by Shane Dillon on November 21, 2006 at 6:15 pm
    I was wondering if there was any other way, other than using FCP, to convert all the P2’s mxf files to Quicktime movies?
    Is there just a simple standalone application? Is there anyone smart enough out there that can write such an application and would license and sell it?
    In a Post-production facility that doesn’t heavily rely on Final Cut, P2 is a little bit of a pain in the Ass.
    Any suggestions or help would be greatly appreciated.
    Shane
    Izoneguy replied 19 years, 10 months ago 4 Members · 6 Replies
  • Shane Ross
    November 21, 2006 at 7:05 pm
    P2 Log by imagineproducts.com.
    But that converts it into a DVCPRO HD Quicktime. You need to have the DVCPRO HD codec installed on your system, and that comes with Final Cut Pro.
    What edit system are you using? There are versions of Avid that work with MXF files natively, and there are converters for Vegas and Premeire (I think) called Raylight. Edius edits the MXF files natively.
    What do you rely on?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Izoneguy
    November 21, 2006 at 8:37 pm
    I was fighting it all the way….
    I am now a happy FCP editor using
    P2.
  • Shane Dillon
    November 21, 2006 at 10:20 pm
    Thanks Shane,
    I’ll check out both of those applications. Are you familiar with either of them? If so do you have any tips when using them?
    Thanks again,
    Shane
  • Shane Ross
    November 21, 2006 at 10:22 pm
    Either of them? I listed one…P2 Log.
    No, I haven’t used it. I tested HD Log, the more expensive version and found it very handy.
    But again, you haven’t told us what edit system you are intending this for. That is a big determining factor.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Barry Green
    November 22, 2006 at 4:14 am
    [Shane Dillon] “In a Post-production facility that doesn’t heavily rely on Final Cut,”
    What do they rely on? If they’re on the PC you can use either http://www.dvfilm.com Raylight to export an .AVI, or you can use Serious Magic’s DVCPRO-HD decoder to export MXF files into AVI files. I think P2 Log is about the only standalone application on the Mac and it converts to .MOV files.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Izoneguy
    November 22, 2006 at 3:17 pm
    Many high-end posts houses that were AVID only are setting up FCP bays….
    They are discovering that many producers are off-lining with FCP
    and many projects are being shot with P2 and they find the P2
    integration is much tighter with FCP. They may go back to the AVID
    for final CC and print to tape.
