Activity › Forums › Panasonic Cameras › P2 to laptop to harddrive – no mountable file system error
  • P2 to laptop to harddrive – no mountable file system error
    Posted by Honestjon on November 7, 2006 at 7:32 pm
    I used about 20 cards – 3 have failed to mount.
    Using a Macbook to copy the cards into – card.cdr – files, that I later mount, then import into FCP.
    17 worked but 3 give a – disk images failed to mount – warning – with the reason being – no mountable file systems.
    is there a fix?
    or do i need to bring to a disk recover service?
    Izoneguy replied 19 years, 10 months ago 2 Members · 1 Reply
  • Izoneguy
    November 8, 2006 at 2:50 pm
    Just try copying the P2 cards into a new folder.
    When you open P2 import in FCP you click on that new folder
    and that will import into FCP.
    And remember to power the card down after ejecting it.
    It is the little icon in the upper right
    next to your display and sound icons….
    This was never fully documented and seems to
    ne the cause of many P2 import problems.
