Activity Forums Apple Final Cut Pro Legacy P2 to After Effects Workflow. HELP!
  • P2 to After Effects Workflow. HELP!
    Posted by Whitlock Dunbar on April 19, 2007 at 11:53 pm
    Here’s our scenario:
    Our footage is shot with the HVX and it needs to be composited in After Effects (Windows XP). We have a FCP5 system but my experience on it is minimal (I’m an AVID guy).
    I know the workflow is P2 -> FCP -> Quicktime -> AE7, but I need help with the import/export settings in the FCP. Bottom line is that several clips were prepped for me, but the quality was very poor; my theory is that data is being lost via an improper conversion.
    Can someone post suggested FCP settings? Also should I assume that the Animation codec is the best lossless export option? I know that’s alot to ask, but ANY help is appreciated.
    If this is detailed elsewhere please post the link; I’ve been searching all day but I’m getting nowhere…
    Whitlock Dunbar replied 19 years, 5 months ago 2 Members · 5 Replies
  • Jeremy Garchow
    April 20, 2007 at 1:33 am
    The problem is that there’s no DVCPRo HD codec for windows. You should import the p2 on a windows machine and i think you need something called raylight to do it.
    https://www.dvfilm.com/raylight/
    Jeremy
  • Jeremy Garchow
    April 20, 2007 at 1:34 am
  • Whitlock Dunbar
    April 20, 2007 at 2:13 am
    If I understand Raylight correctly, it means that I can manipulate P2 media in after effects running on XP?
  • Jeremy Garchow
    April 20, 2007 at 4:21 am
    Looks like it. I haven’t used it as I work exclusively in OSX/FCP.
  • Whitlock Dunbar
    April 20, 2007 at 4:15 pm
    I tested it this morning and yes, the After effects PC read the avi files created by Raylight. Thanks a million!
