Activity › Forums › Panasonic Cameras › P2 store won’t mount on G5
  • P2 store won’t mount on G5
    Posted by Russ Johnson on August 24, 2006 at 4:10 am
    We can’t get our P2 store to mount on the desktop so we can move files to an archive drive. No problem getting the cards in an HVX200 to mount via firewire 400. OS 10.4.3, Panasonic driver installed. What gives? Do we need to update P2 store firmware or something?
    Russ Johnson replied 20 years, 1 month ago 2 Members · 2 Replies
  • Noah Kadner
    August 24, 2006 at 4:16 am
    Have you reset the P2 for Mac access?
    TO GET YOUR MAC TO SEE THE P2 STORE (TAKEN FROM A DV INFO POST):
    To change compatibility mode between Mac and Windows: 1. Connect USB cable between P2 store and Mac or PC, and then turn on P2 store. 2. Make sure USB LED (D) lights. 3. Press CANCEL button (A), Battery level indicator button (B) and HDD capacity indicator button (C) simultaneously for more than five seconds. 4. The color of USB LED (D) is orange for Mac, green for Windows. NOTE : If you follow the instructions in order, the P2 store will not change modes correctly. The correct sequence is to first press and hold the HDD Capacity ( C ) and Cancel buttons (A), THEN add the Battery Check Button (B), now hold all three buttons for 5 seconds, the mode will change reliably from PC to Mac or back to PC. Doing the procedure in alphabetical order will produce hit-and-miss results. As mentioned in the note, it is necessary to connect a USB 2.0 cable to the computer or the USB mode LED will not light and you will not know which mode you have selected.
    Noah
  • Russ Johnson
    August 24, 2006 at 4:30 am
    Noah,
    Thanks for the blindingly quick response. I’ll try it.
    regards,
    -Russ
