Activity › Forums › Panasonic Cameras › P2 Store Question
  • P2 Store Question
    Posted by Steve on February 13, 2007 at 11:47 am
    Ok I have P2 store and have been dumping cards to the store unit.How do I tell which cards are the new folders on the P2 store when each folder is labeled “NO NAME” ? It would be nice if a date or incremental # was there so I could ID each folder. I do not want to keep transfering the same card(s) data that I already transferd, but I have no way on knowing which one went over. Right now I find a video file name and use a search to see if that file has been transfered, and by the process of elimation, I find the new “NO NAME” folder(s) to transfer..any other ideas? I still am keeping the data on the drive as another back-up.
    Jeremy Garchow replied 19 years, 7 months ago 2 Members · 5 Replies
  • Jeremy Garchow
    February 13, 2007 at 2:03 pm
    You have got to get yourself P2 Genie. It is almost necessary and @ $33 US it’s not unattainable.
    https://www.p2genie.com/
    Jeremy
  • Steve
    February 13, 2007 at 7:17 pm
    I have P2 Genie, but it does not tell you which folders are which on the P2 store, you have to ingest first, and you may ingest the same folder 2x.
  • Jeremy Garchow
    February 13, 2007 at 7:45 pm
    I think it assumes that once you transfer the p2 material, you empty the p2 store.
  • Steve
    February 13, 2007 at 8:33 pm
    Well that must be it.
  • Jeremy Garchow
    February 14, 2007 at 1:33 am
    That’s not to say that P2 Genie shouldn’t be fixed, but the p2 store is an intermediary until you can get the footage to your main backup or hard drive system. Once I transfer it off of the p2 store, I then delete the p2 store to make way for more footage.
    Jeremy
