Activity Forums Panasonic Cameras P2 store not working
  • P2 store not working
    Posted by Chris Bell on January 27, 2007 at 2:49 am
    My P2 store refuses to accept data from my P2 cards. When I do a capacity check, I get four red lights flashing. Is there anything I can do short of sending it in for service?
    Chris Bell
    Tyler Faison replied 19 years, 7 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    January 27, 2007 at 5:54 pm
    Did you reformat it?
  • Jeremy Garchow
    January 27, 2007 at 5:58 pm
    By the way 5 red’s means it’s full, usually.
    Jeremy
  • Tyler Faison
    January 29, 2007 at 4:14 pm
    Scenario #1: According to the manual, 4 red lights flashing, in addition to the error light on the front of the unit flashing (5 lights total), means “The voltage is abnormally low.” Putting a fresh battery in should take care of the problem.
    Scenario #2: If the error light on the front of the unit is solid, and the 4 lights on top are flashing, the manual says “After an internal error occurred, copying and formatting is not possible.” You’ll need to contact the place you purchased your unit from and hopefully they’ll be able to replace or repair it.
    Good Luck!
