Activity › Forums › Panasonic Cameras › P2 sound problem workaround!
  • Noah Kadner
    August 13, 2007 at 10:46 pm
    Sounds more like your camera needs repair. You should not need to only use one slot for shooting. Both should work equally well.
    Noah
    Unlock the secrets of the DVX100 and now Apple Color!
    https://www.callboxlive.com
  • Peter Corbett
    August 14, 2007 at 1:49 am
    I’ve heard this issue is fairly widespread. A DOP friend has exactly this problem and the second slot solution does work. It’s not very pratical to use one slot only though.
    Peter
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
  • Jan Crittenden livingston
    August 21, 2007 at 9:44 am
    I don’t think this is wide-spread or there would be thousands of posts as there are tens of thousands of HVX200s. If you are having this problem, as Noah suggested, you should get it fixed. It is not normal and both slots should operate the same way.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
