Activity › Forums › Apple Final Cut Pro Legacy › P2 reader and macpro
Posted by Arnljot Bringedal on January 26, 2007 at 11:35 amhey guys.
I am buying the hvx-200 next week.
What kind of reader do I need for the P2 cards?
(Preferably one that is fast… or are they all the same? )
And also: I have a MBP as well… will they fit in the card reader slot?
*** Norwegian videojournalist & Editor***
Eric Harnden replied 18 years, 3 months ago 4 Members · 5 Replies -
Shane Ross
January 26, 2007 at 3:21 pm[Becker] “What kind of reader do I need for the P2 cards?”
a) The Camera
b) P2 Store – AJ-PCS060G ($1450)
https://www.bhphotovideo.com/bnh/controller/home?O=Search&A=details&Q=&sku=413447&is=REG&addedTroughType=searchc) Panasonic AJ-PCD20 P2 Drive ($1900)
https://www.bhphotovideo.com/bnh/controller/home?O=Search&A=details&Q=&sku=455632&is=REG&addedTroughType=searchd) A powerbook G4 or PC Laptop with PCMCIA slots.
[Becker] “(Preferably one that is fast… or are they all the same? )”
Transfer speeds are all relatively the same.
[Becker] “And also: I have a MBP as well… will they fit in the card reader slot?”
Nope. They are PCMCIA cards, the older G4 Powerbooks had these. The MacPros have PCI express slots.
Shane
Littlefrog Post
http://www.lfhd.net -
Steve Eisen
January 26, 2007 at 7:45 pmThere is a solution for G4, G5 and MacPro users. I have not tried the PCMCIA adapter but I have the SATA adapter and it works very well.
Check out the ComboDock from Wiebetech.
https://www.wiebetech.com/products/ComboDock.phpHere are some adapters you can connect directly to the ComboDock. Check out the PCCARD adapter.
https://www.wiebetech.com/products/v4_adapters.phpSteve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Arnljot Bringedal
January 27, 2007 at 4:56 pmPanasonic AJ-PCS060G
It says that it connects to computer via USB2.0.
I guess that it is not sufficent stable throughput from it, so that I could edit directly from it?
Im thinking:
If I first have to load up the Panasonic AJ-PCS060G from the P2 cards.
AND then transfer from the Panasonic AJ-PCS060G to my MAC, then it will take a LONG time….
( And that kinda blows away the deadline benefits that I saw from P2 )……
Shane Ross
January 27, 2007 at 7:51 pm[Becker] “It says that it connects to computer via USB2.0.
I guess that it is not sufficent stable throughput from it, so that I could edit directly from it?”
You’d never edit directly from the cards. BAD idea. Because they are very expensive you shoot with them, and while you are shooting, transfer the footage off of them to either the P2 store or external HD (if you had a P2 reader) , and then from the P2 store to an external HD for storage so that you can get the P2 store back into the field. That hard drive is now your master tape.
Here, watch this tutorial:
I don’t think that there was a claim of increased speed of this workflow. Although importing from the field drives is much faster than logging and capturing. Transferring the cards to hard drives or the P2 store in the field is pretty fast too, and can happen while you are still shooting, if you have an assistant.
This is an entirely different workflow from tape…very akin to a film workflow where you have to change magazines, and have an assistant camera.
Shane
Littlefrog Post
Eric Harnden
June 22, 2008 at 12:29 amThanks Shane for the great info.
I’m just starting to work with the P2 workflow and found this thread.
That link got changed. Here’s the new location of your tutorial:
https://library.creativecow.net/articles/ross_shane/p2_workflow.php–Eric
