Activity › Forums › Panasonic Cameras › P2 problems when transferring
  • P2 problems when transferring
    Posted by Wesley Whiteside on April 7, 2010 at 4:33 am
    I have a problem transferring P2 card footage to Final Cut. The first two cards worked fine, but for some reason the second two won’t render properly.
    I log and transfer the contents folder and when I play it back, the audio is all sped up while the clip plays in a jagged frame rate. The rendered clip ends before the whole take is finished.
    I don’t know why this is happening. Do you have any ideas on how to fix it?
    Ari Grunzeweig replied 16 years, 5 months ago 2 Members · 1 Reply
  • Ari Grunzeweig
    April 7, 2010 at 1:22 pm
    My suggestion would… in log and transfer, go to your prefs (a small drop down in the middle on top, and then unselect remove duplicate frames…)
    Good luck!
