Activity Forums Panasonic Cameras P2 Portable AG-HPG20 – No flagged frames support
  • P2 Portable AG-HPG20 – No flagged frames support
    Posted by Tim Maloney on February 24, 2009 at 4:39 am
    Hello all,
    Followed a thread below where people were trying to record 10 bit out of the HDSDI spigot from the Varicam.
    Of course ( at least our early model ) does out put 10Bit – with the flagged frames BUT only when not recording on a tape.
    When the tape is running the output of the HDSDI spigot reverts to 8BIT.
    I see discussion also about the P2 Portable AG-HPG20. Nice idea but the deal breaker for me is that apparently – according to our Panasonic Reps in Australia, that unit DOES NOT see the flagged frames from the Varicam.
    Any further knowledge about this potentially great device?????
    JAN?????
    Best
    Tim Maloney
    Axis Films Australia
    Marcus Van bavel replied 17 years, 4 months ago 4 Members · 5 Replies
  • Jan Crittenden livingston
    February 24, 2009 at 11:41 am
    [Tim Maloney] “Followed a thread below where people were trying to record 10 bit out of the HDSDI spigot from the Varicam.
    Of course ( at least our early model ) does out put 10Bit – with the flagged frames BUT only when not recording on a tape.”
    It really depends on if you have the switch on the CAM or on the VTR. Little switch on the side of the camera under the door.
    [Tim Maloney] “When the tape is running the output of the HDSDI spigot reverts to 8BIT.”
    This is because it has gone through the compression and DVCPRO HD is 8 bit.
    [Tim Maloney] “I see discussion also about the P2 Portable AG-HPG20. Nice idea but the deal breaker for me is that apparently – according to our Panasonic Reps in Australia, that unit DOES NOT see the flagged frames from the Varicam.”
    They really should do their homework down there and try it. It does do flagged frames on its recording and I have removed them from DVCPRO HD. I have even pulled out a ramped piece in FCP that I recorded from a Varicam on the P2 Portable. There is a piece of software being developed by DVFilm that will remove the flagged frames from the AVC-Intra. That plug-in will be available about the same time as the P2 Portable.
    [Tim Maloney] “Any further knowledge about this potentially great device?????”
    We have the brochure and operations manual up on our website. http://www.panasonic.com/Broadcast And yes, it is a great little device. A HDD5 machine I can carry in my briefcase. 😉
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, HPX500, HVX200, DVX100
    Panasonic Broadcast & TV Systems
  • Rainer Bergomaz
    February 24, 2009 at 7:19 pm
    one more question. Will the AG-HPG20 also remove the not tagged frames from 720/25p over 60p? If it removes the not tagged frames what will be stored? 720/25p?
    Charles
    February 27, 2009 at 10:46 pm
    This unit will only record 50I 1080/ 50P 720, 60i 1080/ 60P 720. It does not do any removal ar all. It takes in the flags, records them and the Frame Rate Converter remove the extra frames.
    If you want something that does this in record, please take a look at our P2 Mobile, AJ-HPM110.
    Best,
    Jan
  • Marcus Van bavel
    April 11, 2009 at 3:43 pm
    [Jan Crittenden Livingston] “There is a piece of software being developed by DVFilm that will remove the flagged frames from the AVC-Intra. That plug-in will be available about the same time as the P2 Portable.”
    DVFilm’s Raylight MXFX 2.0 will have the capability to remove the flagged frames. MXFX 2.0 will be for sale in late April 2009. Here is a short video explaining how it works with the HPG-20:
    https://www.youtube.com/watch?v=If618j3GN_c
  • Marcus Van bavel
    April 11, 2009 at 3:59 pm
    [Charles Binn] “one more question. Will the AG-HPG20 also remove the not tagged frames from 720/25p over 60p? If it removes the not tagged frames what will be stored? 720/25p?”
    The HPG20 records 720/60P with tagged frames in that case and then Raylight MXFX 2.0 is used to remove them. It’s a pretty quick process and all the metadata is preserved in the final result. The final result is a new (and smaller!) P2 folder with MXF files in 720/25P format.
    It will also work with VFR mode and other pulldown modes, and other cameras. One potential use for example is shoot 48 frames per second for slow motion. MXFX in that case can remove the flagged frames and slow it down to 24P for editing.
